BearingS? i hear a noise
Old Dec 23, 2003 | 02:48 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
hey i hear a noise but i cant tell where its comin from.
it only does it when i drive and its like a constant sound and its starting to get louder after driving it like that after a few weeks.. could it be bearings? i just bought 80 bucks worth of bearings and gonna take it to my dads shop to find out if it really is this friday.. maybe U guys have some ideas?
plz reply
thank you
Old Dec 23, 2003 | 04:17 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
If it's a clunking sound; and it's coming from the rear of the car.... Buy a set of gears while you are at it. You just broke some teeth on the ring or pinion gear. It will only get worse until you finally get stuck on the road.......
Old Dec 23, 2003 | 05:47 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, I agree. It's most likely the ring and pinion. My car sounded like that before it sharpened the ring gear teeth to points and blew three teeth off the pinion gear.
Drive the car at a steady speed and steady throttle application. Then let off the gas and see if the noise goes away, or gets quieter. If it does then it is definately the ring and pinion. The sound is generated by too much backlash, which is a sign that the gears are about to take a dump. It's best to fix it before is grenades, because you'll be able to save a lot of parts that may be destroyed if the gears come apart. Plus the car will be undriveable.
Upgrading to 3.73s is a good idea, since all gears cost the same. Also, check the bearing surfaces on your axels while the rear is apart. If they are wasted replace them. Do the axel bearings and seals too.
Old Dec 23, 2003 | 08:26 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
its not clunking , is a constant low noise that i hear only when i drive it, i gotta have the radio down just to hear it. i hope to *** its not the rear, i just replaced that last year and i cant afford to do it again. it took 9 hours to do it and several hundred dollars
i think its comin from the right side somewhere to be honest.. but i dunno from rear or front.. yet.. i'll find out this friday when i get my dad to look at front wheels.
thats the problem that Scares me, i frequently let off the gas and try to keep myself quiet as i can just i can try to pinpoint where that sound is coming from.
why would it keeep making that sound after i let off the accelerator??
is the rear end collapsing on me?
the driveshaft imploding??
if im at risk of dying in my own car i wanna know
someone please reply if U know anything about this sorta thing..
Old Dec 24, 2003 | 11:35 AM
Could also be an axel bearing. Pull and check the axels like I said. The shafts are most likely wasted after this much time and require replacement.
Old Dec 24, 2003 | 12:34 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
thats a good point... it could be the axle bearings.. i hope its not but i got some brand new never open rear bearings and seals in the basement that i never used.. i'll bring them too when i go take it in
thank you
Falcon50
Aug 22, 2020 03:26 PM
92projectcamaro
Dec 8, 2015 12:25 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
