T-56 and 3rd gen wire harness?
Old Dec 24, 2003 | 03:17 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am using a speed density harness and I have a T-56 installed. Now the connector that went to the VSS on the 3rd gens must be different because I can't find a place to hook mine up. Which one of those 4 connectors on the T-56 is the VSS? and do I have to install a 4th gen connector to make this work?
Old Dec 24, 2003 | 03:21 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I bought the 4thgen pigtails and spliced them into the 3rdgen harness.
You'll need:
T-56 reverse light and VSS pigtails and a Dakota Digital SGI-5 cal. box to get your speedo working.
Hope that helps!
Old Dec 24, 2003 | 03:49 PM
Car: 1992 Camaro
Engine: 350 miniram
That sure does. I got the SGI-5 box so now all I need are those 4th gen pig tails and I should be on my way. Thanks
Old Dec 25, 2003 | 02:24 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Here are the GM Part Numbers for the T56 related pigtails:
VSS 12101899
Reverse Light Switch 12085485
Reverse Lockout Solenoid 12101857
Hope that helps.
Old Dec 25, 2003 | 06:54 PM
demonchild's Avatar
some poeple on the so cal board retrofited a 3rd gen vss to a t56 tranny. it looks trick. maybe you can search for the post in that forum.
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
