Differental Fluid?
Old Dec 27, 2003 | 10:56 AM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
Differental Fluid?
im swapping a damaged rear axle out of my 91 rs with a new set off ebay. im wondering what type of replacement differental fluid i should use and how much? thanks
Old Dec 27, 2003 | 10:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
One of the beter synthetics, such as Mobil1, Amsoil. Red Line, etc. 75W-90 or some such. The exact numbers aren't real critical. NOT the super thick stuff like 85W-140.
Old Dec 27, 2003 | 11:52 AM
ede's Avatar
ede
i use M1 and amsoil 85w-90 with no problems. if you have a clutch type posi use the gm posi additive.
Old Dec 27, 2003 | 12:07 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
85W140 is just VERY slightly (only ONE step!!) thicker than 75W90, and is a very good choice for our axle's!!
85W140 synthetic has almost the same weight as 75W90 dino!!(but is superior in every way!)
Synthetic oils are due to the way they are made always slightly thinner when compared to a not synthetic oil of the same specifications.
You just can't compare weight specs. of engine oil with gear oil!
F.i. XW90 gear oil compares to Xw40 engine oil and XW140 compares to XW50 engine oil (you see, only ONE step.....)
Know what you're talking about before giving any advise!!!!
Old Dec 30, 2003 | 03:45 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
I have a question related to this, I have read somewhere that with the top of the line synthetic rear end lubes, ie. Royal Purple, Red Line, etc., the posi additive is not required. Is this a true statement or is it bogus. Thanks in advance.
Old Dec 30, 2003 | 03:50 PM
ede's Avatar
ede
that's what they say but for 6 dollars a bottle i'll use the gm posi additive reguardless of what the oil makers say
Old Dec 30, 2003 | 06:14 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
when i put in my slp zexel torsen, do i need to use the posi additive, cause it doesnt use clutches does it?
Old Dec 31, 2003 | 05:12 AM
ede's Avatar
ede
don't need the posi additive if you don't have clutches.
Old Dec 31, 2003 | 07:09 AM
joshwilson3's Avatar
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
