2 Simple Questions!
Old Dec 29, 2003 | 05:06 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
2 Simple Questions!
I want to know if going to 3.73's would be worth it. I have 3.42 now and they seem fine but I want It to pull faster and harder at the track. BTW I wind it to about 6000 at the track.
2. I would like to know what converter you guys recommend for my combo. I have the B&M tork master 2000 now and it feels like a stock converter I can only manage 2.1 60 ft times with 255/60-R15 and no wheel spin. I want to be able to shred street tires and need slicks to hook up.
Cam is Hyd/Roller
218/228
.492/.492
112 LSA
Old Dec 29, 2003 | 05:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's not much difference at all between 3.42 and 3.73.
I'd get a converter first. With the cam you have, look at 2600-2800 RPM stall. I'd be inclined to suspect that even with that tiny carb that's too small for the motor, the engine doesn't get into it's powerband for the first 100 feet or more. That's why your 60s suck.
You'll get a whole lot more bang for the buck out of that, than you will out of that little tweek to the gearing.
Old Dec 29, 2003 | 06:26 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I'll second that
Your gears are fine. Go with a higher stall converter.
Old Dec 29, 2003 | 11:25 PM
Ezey Go's Avatar
Definitly get a higher stall converter first. You wont gain much going 3.73 if you have 3.42.
Old Dec 29, 2003 | 11:35 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You need to figure out if you will stay in your power band when you cross the traps if you go to a 3.73. You may rediline beofer you cross the line and that won't help your ET's. I agree with everyone else that you should change your converter. A 3.42 gear is an all around great gear.
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
