rear axle seal leaking
Car: 92 Camaro RS
Engine: 305 TBI
My rear axle seal is leaking, and I was wondering about putting in a posi rear end, and the best gear ratio to go with. It is a 92 RS with a 305 tbi, and 770R4 tranny. I primarily use the car as a daily driver, but I do want to hop the car up to the next level. Thanks.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
3.42 or 3.73. You would want a little bit higher stall converter with the 3.73s, and a bigger cam, better intake, & better heads also wouldn't hurt. All assuming that the exhaust has already been opened up.
I'd go with the 3.73s because they offer you more flexibility down the road as you make other improvements.
Car: 92 Camaro RS
Engine: 305 TBI
Sorry my typing was off yesterday, it is a 700R4 Transmission, I will have to crawl under the car tomorrow to find out which ratio I have. Thanks
