v8 t-5 to a v-6 vehicle??
Just wanted to double check everything....
The v-8 t-5 will bolt to the v6 vehicle with the v-6 bellhousing and flywheel. Use the v8 clutch due to splines on input shaft, correct??
the lengths of input shafts didnt change did they??
Car: Camaro
Engine: 3800
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
find a 9 inch clutch disc with 26 splines and it will work
MIGHT have to cut the pilot very little
why tell someone to do a search when its easier to type a short answer?
Originally posted by 67 Camaro 88
EDIT: That was too much fun to pass up, and I was bored... didnt mean for it to come off a*sish
[/B]
[/B]
Thanks for the reply 91Teal, What about a pressure plate, i guess if you used the smaller clutch with the v6 flywheel, you could just use the v6 pressure plate?
