T5 work with a stock 305?
Old Jan 1, 2004 | 09:30 AM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
hey guys i have a basically stock 305 LB9 tpi. i will be putting a full exhaust on here soon and since i may have wrecked my tranny i am looking into puting a t5 manual into my car. im not looking to run it hard a lot and most of the time it will just be a cruiser. i would like to take it to the track maybe twice and a street race like every 3 monthes since we dont get much action. i was wondering if the T5 can hold up to a most normal driving and a little roughness every once in a great while.
Old Jan 1, 2004 | 09:51 AM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
My 305 came sock with a T5 so I guess it;s ok )
Old Jan 1, 2004 | 10:07 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It should be fine. Traction is what usually kills them. Also, make sure you get a good aftermarket shifter, because the stock one is junk and can cause you to miss shifts that can also kill the trans.
Old Jan 1, 2004 | 10:10 AM
Kevs87Z28's Avatar
Engine: 355 Carb
is there somewhere i can look to buy a kit that i can buy that has everything i need? what kind of shifter? i have never driven a manual before but my friend is suppose to teach me in the next few days with this truck his gf is selling. any tips for what transmission to get? is a junkyard tranny good enough? one of those pick and pay type places is around here with a crap load of 3rd gens and i might find a manual there. any advice? im just so lost.
Old Jan 1, 2004 | 10:15 AM
Get the trans out of a V8 car. The V6 ones aren't as strong, and the bellhousing won't work.
I exclusively use Pro 5.0 shifters. They aren't the cheapest, but I feel they are the best. I never seen or heard of one failing.
There are probably several setups for sale via the classified section of this site. A trans out of a junkyard is always risky. It isn't a bad idea as long as they give you a warranty. T5s are cheap to rebuild, so even if you got stuck with one that is screwed up it can be fixed for fairly cheap.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
