Anyone running a Diff Temp Guage?
Old Jan 4, 2004 | 12:06 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Just wondering who is using one and what temp the differential normally runs at.
Old Jan 4, 2004 | 01:04 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Well, engine oil temp is supposed to be about 270 Farenheit I believe. I wouldn't think gear oil should get any hotter than that.
I would only think that this would be a problem in open road racing or high speed endurance racing. I know that the NASCAR guys actually run a pump and a cooler for the rearend.
Old Jan 4, 2004 | 04:33 PM
Zepher's Avatar
I plan on running my car at open track road racing events when it's finally done.
I am just looking at things to add to the car while it's all apart.
Old Jan 4, 2004 | 11:13 PM
Well in that case tap a hole in the bottom of the case so you can install a sender, and just get an oil temp gauge. You want the hole in the bottom, because the sender needs to be imerssed in oil to function accurately.
What rear are you running?
Old Jan 4, 2004 | 11:22 PM
Zepher's Avatar
I am running a 99 LS1 rear end with Motive 4.10 gears.
Old Jan 4, 2004 | 11:28 PM
Then you're good to drill and tap. If you had a 9" you'd need to weld in a bung.
If it is getting too hot I'm not sure what you can do about a cooler. All the ones I've seen are for 9" rears. They specially prepare the pinion with a cam section to drive a pump, or they run a yoke with a pulley on it. You may be able to do an electric pump, through a small oil cooler with a scavenge and a return port tapped into the case. Just some ideas...
Old Jan 4, 2004 | 11:43 PM
Zepher's Avatar
Well, I am still building the car at the moment, but I want to do as much as I can while it's down.
I like the idea of the electric pump setup. I am going to look into that.
Ghettobird52
Jul 5, 2024 11:18 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
