4th gen. rear end
Car: 1991 trans am
Engine: 383
4th gen. rear end
Ok, ok, yes I know that a fourth gen rear end can be swaped in place of a third gen with only the addition of a few inches wheel offset. Now this question isn't only drivetrain, it is about rear disk as well. I just want to make sure I understand everything before I have the chance to mess it up
If I were to swap a 3.42 posi disk rear end in place of my crap 2.73 open drum rear what all is involved?
I know that it is wider. I know that the gearing for my speedometer needs to be changed. And I know that I need a proportioning valve to increase pressure to the rear breaks.
Do I need a new master cylinder? Do I need new break lines? Does the torque arm still bolt up correctlly?
Any help and or suggestions are appreciated!
Thanks,
Jim
Thanks,
Jim
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 4th gen. rear end
No you can reuse your stock one
No but you may need to stretch them a bit to fit. However you will need a new E-brake cable I think. I cannot remeber off the top of my head. Can't remeber if my buddy is getting one because his was broken or because of his new rear.
Yes sir it does. The two rear ends aisde frim the width are identical. When you put the two side by side they look the exact same.
left in stock master cylinder used the new brake lines on the rear end the flex and steel ones the only thing i had to modify was the e-brake cabling do a search about e-brake and it'll show you and i also put 4thgen wheels on my car too
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Originally posted by JADIII35
Thanks for the help! Does anyone have any helpfull hits that I shoiuld be awhere of before hand?
Thanks,
Jim
Thanks,
Jim
Car: 1991 trans am
Engine: 383
Thanks for the help and advice guys! I had tracktion problems in the past, so the listed upgrades have been mostly completed already. Lakewood control arms, and poly bushings. The springs aren't that old. And I have an aluminum drive shaft, larger swaybar from the factory ws6 package.
Thanks again,
Jim
Thanks again,
Jim
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
