Limited Slip VS Posi
Old Feb 7, 2004 | 08:35 PM
  #51
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
A Powertrax Lock Right will cost about $330 (just a set of new guts for a stock open case, but acts like a locker once installed). A real deal Detroit is over $550.
Old Feb 7, 2004 | 08:43 PM
  #52
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
u guys are animals
Old Feb 8, 2004 | 01:17 AM
  #53
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I got my Powertrax for like $330 I think it was a couple years ago, but was recently pricing them in Summit and such and they seemed to be running around $400 now, perhaps they have a newer more expensive model or something... Another plus with these is you can install them yourself, no gear setup, no special tools, etc.
Old Feb 8, 2004 | 09:19 AM
  #54
Pat Hall's Avatar
I went with the powertrax in my one car for the same reason as Ray did. You can install it in your driveway with no special tools or setup required in about an hour. It's a piece of cake. It's also reassuring to hear other people on here say how indestructable they are since I'm running a lot more horsepower in that car and mainly built it to go fast in a straight line. If your car is fairly close to stock and you use it mostly for a daily driver, I'd still have to recommend a clutch style posi for it instead though. I'm sure the day will come when the posi burns up in my 89, and at that point in time, I might try out a zexel-torsen unit in it, or maybe a rebuildable eaton unit if I happen to come across a good deal for one somewhere down the road.
Old Feb 8, 2004 | 11:12 AM
  #55
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
can you install the powertrax unit in a rear that was a posi, or is it just for originally open rears. i don't know alot about rears so any help would be great. i don't dive my car every day. i need something that will hold up to numerous visit to the drag strip.
Old Feb 8, 2004 | 11:38 AM
  #56
The Powertrax needs to be installed in an opne rear end. The posi cases are different.
They are still about $330 from Randy's Ring & Pinion. Summit's rear end stuff is overpriced.
Old Feb 8, 2004 | 07:35 PM
  #57
25THRSS's Avatar
What do you mean the posi cases are different?
Old Feb 8, 2004 | 07:46 PM
  #58
85TransAm406's Avatar
Car: 1985 Trans Am
The posi cases are different than an open rear, as the powertrax locker replaces the spider gears in the open diff.
Old Feb 8, 2004 | 07:52 PM
  #59
25THRSS's Avatar
So the powertrax locker actually goes inside the case of the old open differential? Do you just gut the old one or something? I thought it replaced the entires posi unit as a whole.
Old Feb 8, 2004 | 07:55 PM
  #60
Car: 1985 Trans Am
yes, the lock right they are talkin about goes in pretty easy, as easy as taking out the center pin and c-clips, then the spider gears come out pretty easy, and the case stays in, so there is no re-setup of the gears or diff.
Old Feb 8, 2004 | 07:58 PM
  #61
25THRSS's Avatar
hmmm, interesting, i learn something new every day
KO1
16
Oct 15, 2015 05:00 PM
racereese
Oct 3, 2015 03:46 PM
