A Gallon Low
Old Jan 6, 2004 | 11:22 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
A Gallon Low
My 5-speed was feeling funny, so when I got new tires I had them check it and it was a gallon low. What kind of damage could have occured? I was still running low 15's though.
Old Jan 6, 2004 | 11:38 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It doesn't hold a gallon to begin with. A T56 barely holds a gallon. Damage depends on how long it was like that. It could range from nothing to smoked bearings and blocker rings.
Old Jan 6, 2004 | 11:41 PM
Engine: 5.8
Pep Boys said about a gallon and it was for about 6 months.
Old Jan 6, 2004 | 11:45 PM
Pep Boys doesn't know jack about cars! A T5 holds about 3 quarts total, maybe less.
Is the trans making any noises or being difficult going into gear? If not you're fine. If so soemthing is damaged, and a rebuild is in order. The full kits are only about $185 though.
Where did the fluid go?
Old Jan 7, 2004 | 05:43 AM
ede's Avatar
ede
only way it's take a gallon is if they poured a quart or so on the shop floor. like tko said the big question is where did it go?
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Damon
Sep 26, 2015 04:29 PM
