decoding rear axle numbers
Old Jan 7, 2004 | 01:09 PM
jeriatric's Avatar
Does anyone know of any websites where i can decode rear axle numbers for 3rd gens???
Old Jan 7, 2004 | 02:11 PM
ede's Avatar
ede
www.thirdgen.org
Old Jan 7, 2004 | 02:28 PM
jeriatric's Avatar
Where would they be listed? I've been looking but can't find them.
Old Jan 7, 2004 | 04:55 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
http://www.hioutput.com/tech/ratio.html
Old Jan 7, 2004 | 08:13 PM
jeriatric's Avatar
Thats exactly what i needed, thanks.
Old Jan 7, 2004 | 10:55 PM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
You may have got your answer already so this is meant to just be another source, that is if you are talking about the codes on the passenger-side axle tube. I found a big chart in the current Haynes repair manual for Chevy Camaro '82 thru '92 in the rear end section.
Hope this helps someone
K
Old Jan 8, 2004 | 12:43 PM
jeriatric's Avatar
I'll check that out too, thanks
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
