Cant get our of 1st gear, governor problem?
Old Jan 7, 2004 | 09:21 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
From what I've heard/read, it seems like the most likely cause for not being able to get out of first gear is a bad governor gear. Would that also cause me to not be able to manually shift from 1 to 2? I havent looked at my tranny lately to verify this, but will fluid be spewing from the cap when I remove it to inspect the gear? Thanks!
Old Jan 7, 2004 | 09:36 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
My experience has been that this has "something" to do with the governor. Stripped gear, stuck valve in the governor, governor screen is partially or fully plugged.
I suggest you do the easy stuff first. Remove and clean/inspect the governor.
Old Jan 8, 2004 | 08:48 AM
Scott_92RS's Avatar
Car: 1992 RS
I found an AC Delco part number online, listed as "Governor": 24202118. Is this just the gear, or the entire assembly?
Old Jan 8, 2004 | 09:02 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I believe that is the part# for a remanufactured governor assy. What I have done is to go to the junk yard and remove several (many) TH700R4 governors. If I find a malfunctioning governor in one of my cars, then the chances are that I will have a good used one to replace it with.
junkcltr
Aug 2, 2019 11:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
crazynights
Aug 21, 2015 06:53 AM
jbd1969
Aug 17, 2015 07:06 PM
