flywheel swap, will it work?
Old Jan 8, 2004 | 09:14 AM
AFcamaro's Avatar
I am swaping my 90rs T-5 into my 85 z-28 that blew its 700r4. I need to know if i will have to purchase a new flywheel, (will it bolt up ) or can i just use the one from the 90? I would like to know because i have a limited time to get this done and would like to have all the parts ready to go, and just put it all together at once. Although i know that nothing ever goes to plan! lol
thanks for you help
john
Old Jan 8, 2004 | 09:36 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
If your 85 is a two piece rear main seal (original engine) Yes you will need a different flywheel. The one on the 90 has a counterweight on it that the two piece will not + the bolt pattern is different.
Old Jan 12, 2004 | 04:57 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You need a 153 tooth flywheel for the '85 motor, which I believe will be a two piece rear main seal. Verify this for yourself though. The flywheel will need to be a neutral balance.
Old Jan 12, 2004 | 04:59 PM
Hey Nova, is that a '73 or '74 model car. I have the remnants of a '74 SS. The car was too far gone to restore (massive rust). Got good money for the parts on eBay though.
Old Jan 12, 2004 | 05:37 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
73 like in my sig really no diffenences between the two except 74 got stickers instead of metal emblems
Old Jan 12, 2004 | 06:47 PM
Duh, I just noticed it in your sig.
What motor/trans/rear you running? My car was a 305/M21 Muncie/12-bolt posi with 3.31s. There are a few little differences, but by and large the two years are very similar.
Jorlain
Aug 24, 2022 05:11 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
