How do i convert the speedo sensor from a 91Z28/700-R4 to a T-5 from a 85 TA???
Old Feb 28, 2003 | 04:23 PM
91 Camaro Z28's Avatar
hey people, i'm about to do the 700-R4-T-5 swap in my 91 Z28
the T-5 tranny is coming out a 85 TA. As far as I know the speedo setup in my 91Z28 is a vehicle speed sensor/electrical setup, and the one that the t-5 uses is mechanical
Whats the best way to get my current electonic speedo to work with the mechanical one from the 85 TA T-5?? please help as i'm clueless about this stuff.
Old Feb 28, 2003 | 05:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put a mechanical speedo gear housing and gear in the T-5.
Total no-brainer.
Old Feb 28, 2003 | 05:46 PM
ctandc's Avatar
I think you worded your post wrong.
Your 91 Z28 uses an electrical connector for the speedo. The 85 T5 uses a mechanical speedo. You need the speedo setup off a T5 with the electric speedo......
When are you doing your swap? I'm swapping a '92 T5 into my 85 IROC and I have to remove the 92's electrical setup for a mechanical speedo housing and gear anyway, so if you want, we could swap.
Email if interested.
HTH
Old Feb 28, 2003 | 07:46 PM
will the electric speedo setup from a 91 Z28 T-5 plug right into the T-5 from the 85 TA Donor car?
Old Feb 28, 2003 | 08:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yes
Old Mar 10, 2003 | 11:06 PM
so all i need is the speedo sensor from a 91Z28 T-5 to plug into the 85 Trans Am T-5?
Old Mar 11, 2003 | 07:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
yes
and of course the correct gear to go with your rear end gears and all that, just like any other speedo situation.
FYI, I went the other way.... 91 trans into 83 car.... direct bolt-in. One 10mm head bolt.
Old Jan 12, 2004 | 07:56 PM
mckenzie's Avatar
hello, i just bought a 1991 z28, and the speedometer jumps around...well, i think i might have figured out why. got the numbers off the trans, and its off a 1992 truck ...diff speed sensor than the cars 4l60 trans. anyway, how hard is it to change to the correct speed sensor? any help would be great. thanks, tom
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
Cacike
Aug 27, 2015 05:10 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
