my rear
Old Jan 8, 2004 | 02:44 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
my rear
i have an 89 trans am 305 with 2.73's and i am getting 3.73's and a ring spacer. is my rear a 10 bolt 7.5 rear?
so to make 3.73's work i would need:
http://www.speedwaymotors.com/produc...No=1&redirect=
the ring spacer for 44 bucks and then with these gears...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452806950
and my last question is what if i get a posi unit do i still need the ring spacer? and if i get a posi does that need to be 7.5 also?
and if i buy a posi unit will this one be ok/
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452709830
and another thing i just found was this site. will this whole setup work in my rear?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452432761
Old Jan 8, 2004 | 03:53 PM
ede's Avatar
ede
you can buy a gear set that doesn't require a spacer. doesn't matter if you have a posi or not it's the series carrier and gear set that matches that makes the differance. i'd stay away from used parts on ebay.
Old Jan 12, 2004 | 10:19 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Just get a 3 series carrier and then you don't need the spacer.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
