what differential fluid should i use???
Old Jan 9, 2004 | 06:09 AM
SeanTimothy's Avatar
wlel....got my 3.73, posi, and rear end master install kit , new bearings yadda yadda....what diff fluid should i use???? what weight, brand , etc....
Old Jan 9, 2004 | 06:34 AM
ede's Avatar
ede
i use either m1 or amsoil and gm posi additive.
Old Jan 9, 2004 | 08:10 AM
what weight? how much do i put in?? sorry, never dropped the cover before, i dunno much about it.
Old Jan 9, 2004 | 10:01 AM
25THRSS's Avatar
I use amsoil 80w90. It is the only synthetic fluid I could find in that particular weight.
Old Jan 9, 2004 | 10:17 AM
ede's Avatar
ede
long as it's gear oil weight doesn't make much differance unless you want something like 140w. most you'll find is between 75w and 90w with 90 to 120 as the other number. fill it till it runs out the fill hole, around 2 quarts.
Old Jan 9, 2004 | 12:00 PM
i assume synthetic is the way to go...
Old Jan 9, 2004 | 12:52 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
royal purple any good? was gonna use it when i get my new rear end.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
