Firebird and Camaro drivelines?
Old Jan 12, 2004 | 12:58 AM
Z28MadDog's Avatar
Car: 1990 Jeep Cherokee(college is in upstate NY, lots of snow) 1985 Camaro project car
I am currently in the process of tossing together a 1985 Camaro, and my brother's boss has a firebird of around the same year (not sure what exactly). My question here is are the drivelines the same thing or compatable in order for a switch to take place?
-Thank-you in advance for any help-
<----<<Brandon>>---->
Old Jan 12, 2004 | 01:14 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Firebird and Camaro drivelines?
Yes. If I'm remembering correctly, the only auto trans. offered in 85 was the 700-R4 & manual was T5. Same length driveshaft.
Old Jan 12, 2004 | 06:10 AM
ede's Avatar
ede
basically anything from a 3rd gen f body will work. what exactily are you wanting to swap?
Old Jan 12, 2004 | 06:18 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I think they changed the 700-r4 transmission in '88 something like that. Their wasn't any major change in it's bolt up ability it was just internal improvements and case. Pro-Built uses the later version cases on all his build ups unless you request the older one.
I found some info from http://www.darklair.com/monte/200.vs.700.html
"-Most trans companies agree that the early 700-R4s had some durability problems and must be highly modified to make good performance engines. (didn't say what the mods are)
- the early 82-84 700-R4 units had a smaller 27-slpine input shaft and should be avoided.
- the 85-87 700-R4s can be upgraded but both companies recommended starting with an 88-93 700-R4 "
Old Jan 12, 2004 | 09:00 PM
Z28MadDog's Avatar
Well, the firebird that my brother found has a 350 driveline in it, and my car currently has a 2.8 in it. Bothare automatics, we were just wondering if they are swappable. Thanks for any help
Old Jan 12, 2004 | 10:38 PM
Engine: 383 SBC
I think the bell housing bolt patterns might be different.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Linson
Aug 21, 2015 02:12 PM
antares57
Aug 6, 2015 07:47 AM
