2 series diff housing vs 3 series...
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What's the difference in the housings? Can I use a 2 series housing, with a 3 series gear/carrier/axles, etc?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Go right ahead. The only difference between a 2-series and 3-series is the thickness of the flange on the differential carrier to which the ring gear bolts to. The 2-series has a thinner flange to space the ring gear farther away from the pinion centerline to allow room for the greater number of teeth of the pinion gear.
Pete
Pete
On second thought, the flange may be the same thickness, just located farther from the pinion centerline.
So are you saying I *can* use a 3 series carrier/gears, in a 2 series housing?
Car: `86 SS / `87 SS
Re: 2 series diff housing vs 3 series...
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Yep, 2 of my three rear ends were 2 series with a 3 series gear. My posi was a 2 series and the first rear I used factory 3.42 so I had to buy a spacer to make it work. If your using new cogs then your all set since the new ring gear will already be thicker to compensate for the 2/3 series dilema
