2nd gear out in t-5????
Old Jan 15, 2004 | 08:39 PM
chad89ta's Avatar
hey guys i need your help,my 2nd gear is out on my t-5,does anyone no who makes a bolt in replacement for the t-5 that can handle 400 hp,of so who and give me a web site if you can, thanks chad
Old Jan 19, 2004 | 04:35 PM
HesterZ28's Avatar
Car: 97 30th Z28
Engine: lt1
Transmission: 4l60e
Just do a th400 swap with a stall
Old Jan 19, 2004 | 04:45 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You could beef up your own tran pretty easy. About the only special tool you need is a bearing puller. You can get away with a brass drift if you have to thou.
Old Jan 19, 2004 | 05:26 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
you can get the tremec tko,or the t-56 from 94-97 the 93s have a different gear ratio inside but you can use it as well,a turbo 400 or a turbo 350 will put a damper on hi speed(freeway)and fuel mileage,if you are only racing then of course it does not matter..
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
