what rearend will fit
Old Jan 15, 2004 | 10:44 PM
yellow_Z's Avatar
Car: 84z28
Engine: 406
im looking for tech articles on how and what rear ends will fit in my 84 z28 or any other sugestions or if you have done it thankyou
Old Jan 16, 2004 | 01:30 AM
MdFormula350's Avatar
well if u dont like the rear ratio u have and might not have posi or its broke. your best bet is to find a used 89+ thirdgen rear end. try to find one with disk brakes, and a nice ratio. doesnt really need posi because you can get one from www.slponline.com for 100 bucks and it will fit in that 10 bolt perfectly because it should have 28 spline axles. plus the disk brakes are a good upgrade from the older disk brakes, and even the parking brake seems to be a better design.
all thirdgen rear ends bolt into any other thirdgen perfectly just a matter of hooking up the parking park lines and a different proportioning valve from the newer thirdgens with disk.
a nice 10 bolt with good ratio and posi with disk is a pretty decent rear end and should be able to get all that done for under 500 bucks if u dont the work yourself.
Old Jan 16, 2004 | 06:54 AM
ede's Avatar
ede
any rear from any third or fourth gen f body will be direct bolt in. aftermarket rears can be had from currie, moser, and strange.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
