need help with gears
Old Jan 17, 2004 | 03:13 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
ive got a 9 bolt .277 rear gear ratio in my 89 formula 350 and im gonna change it to 373......can anyone tell me about the rear end i have now.26 spline?...30 spline? my posi unit works great so im not gonna change it...does anyone have any info about where i can get a good cheap set of gears for this car that will work in it? anyone?
Old Jan 17, 2004 | 04:01 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
use 9bolt AND 3.73
Old Jan 17, 2004 | 10:43 PM
stuart's Avatar
does a 373 require a 3 series carrier or can i get a 373 gear and pinion that will fit what i have?......thanks
Old Jan 17, 2004 | 11:28 PM
jmd's Avatar
jmd
twelve.
Old Jan 18, 2004 | 07:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK there are no "special" thick gears available for 9-bolts, and no ring gear spacers either.
You'll need the right carrier.
All that about spline counts doesn't apply. That's 10-bolt stuff. You have a 9-bolt, and all of them are the same in that regard, so just make sure you buy 9-bolt parts.
Old Jan 18, 2004 | 01:27 PM
stuart's Avatar
a buddy of mine has a rearend out of his s-10 that is all new....he wrecked the truck and might sell the rearend out of it and it has 355 gears with a new posi unit........will this fit in my 89 formula?......thanks
Old Jan 18, 2004 | 01:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.... the S-10 has a 10-bolt; and in any case, it won't bolt to one of these cars, because it won't have the torque arm provisions. But if you had a 10-bolt, the gears out of it would fit your F-body 10-bolt, although I'd throw that crappy Eaton Gov-Lock (if that's what he still has one of) in the trash.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
