Bowtie 4th Gear Pressure Switch
Old Jan 18, 2004 | 10:46 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I'm installing a Bowtie Lock-up kit and 4th gear pressure switch has two contact for the wire connectors, however the direction do not state what connector pin goes to what wire. You have one (Red) wire that come from the self grounding solenoid and the other (Red) from Connector case. The numbers on the back of the switch is 1, 2, F, and 4. The F and 4 are in line with the connector pins but, which wire from self grounding solenoid and case connector goes where on the 4th gear pressure switch. Maybe it really dont make a different?
Old Jan 18, 2004 | 11:37 AM
Nordbert's Avatar
I wired mine like this, but the switch was Normally Open, NOT
Normally Closed as in the drawing. The hot wire (ignition key to ON) from the case connector goes to one side of the N/O 4th gear
pressure switch. The wire from the gronded TCC solenoid goes to
the other side of the 4th geard pressure switch. When tranny shifts to 4th, the N/O switch closes and the circuit is completed.
http://www.technicalevolution.com/700wire.gif
Old Jan 18, 2004 | 01:40 PM
DTL504's Avatar
I guess it really does not matter what wire is hook up to what side of the connector on the 4th pressure switch.
89GTAOz
May 16, 2020 09:31 AM
jklein337
Sep 19, 2018 06:23 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
dhonda200
Aug 11, 2015 11:50 PM
