T5 inspection question
Old Jan 17, 2004 | 10:11 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
I just bougth a T5 out of a car from a junkyard and wanted to check what it looks like inside. I tried, but the cover on the top seems to be connected to the shifter somehow because when I move the shifter with that cover loose, the shifter can move the cover. Is there any way I can check out the guts?
Old Jan 17, 2004 | 10:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 inspection question
You must remove the speedometer driven gear, knock down the roll pin in the shifter lever block, unbolt the tailhousing, pull tailhousing back, and then you can lift the cover off including the shift rail.
Frozer!!!
Jan 19, 2024 04:55 PM
GTAman
Mar 15, 2019 11:40 AM
RedLeader289
Jan 22, 2016 03:05 PM
Mickeyruder
Sep 2, 2015 02:45 PM
redmaroz
Aug 16, 2015 11:40 PM
