is it a ford 9-inch???
Old Jan 18, 2004 | 09:51 PM
ChevyCamaro4lif's Avatar
when i bought my 91 the previous owner said it has a ford 9 inch rear end with 4:10 gears and 35 spline axles.....well it def has that gear ratio cause i can tell when driving, but if i were to stick my head under the rear end, how could i tell if i have a real ford 9 inch?
Old Jan 18, 2004 | 10:58 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Smooth backside of the rearend. No bolts. Drop out centersection.
Old Jan 19, 2004 | 04:56 AM
ede's Avatar
ede
pinion set very low in the center section compared to the ring gear.
Old Jan 19, 2004 | 08:53 AM
alright im gonna take a look for these asap anything else to look for?
Old Jan 19, 2004 | 01:21 PM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
Here is what the 9" looks like. This one is in my 75 Camaro. You probably don't have a ladder bar setup, so forget the coil over springs and such. Tim
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
