Storing Transmissions
Old Jan 19, 2004 | 08:27 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
I would like to know the best way to store a transmission, weither manual or stick, so as not to have problems when I go to use it a year later. There hasn't seemed to be any troubles just having them lay there, but I want to know the "best" way.
Thanks guys
Old Jan 19, 2004 | 08:58 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Wrap it in cosmoline and put in in a box. I've seen WWII era parts packed like this that look brand new. Don't know where you can get cosmoline though...
Old Jan 19, 2004 | 09:04 PM
Blue1989RS's Avatar
Car: 1989 RS
Well....I don't mind if it doesn't last 50 years But I guess that it would be great if it did! I just want to make sure that the inside doesn't rot out. So far, all I do is wrap the end with a sandwich bag and zip tie it on there. Then I make sure that it is full of fluid, so there's no "dry rot".
I guess it isn't such a big deal with manuals because they use gear oil, but I want to make sure that the auto's stay good.
Old Jan 19, 2004 | 09:15 PM
The biggest enemy of anything is storgage is moisture. Stick a desicant bag or two in the platic bags you use over the ends of the trans. This should keep any moisture out.
RedLeader289
May 28, 2019 01:47 PM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
ironbmt
Sep 27, 2015 06:00 AM
blackandblue02
Sep 10, 2015 08:19 PM
