A couple 700r4 questions
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
Well i just got a 700r4 out of a 88 or 89 T/A and it appears that the speedo gear is electronic. I there anyway to convert it to mechanical without getting a whole other tailshaft?
And is there a way to make a manual lockup switch without buying the kits? I'm not running a computer anymore. I was thinking just run the wires off the connector on the trans and throw a switch in there. Good or more complicated?
thanks for any help!!!
Exchange the gears, from the old to the new, that's it. If you run a manual switch, hook it to the brake switch to unlock it when you deaccelarate. Remember at high throttle openings to turn off the lockup switch.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
It's fairly simple to build a lockup system with a relay that won't require you to even think about it. There's a link to it somewhere on this forum. Do a search and I'm sure you'll find it.
