what will be the best gear ratio....
Old Feb 2, 2004 | 10:42 AM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
well this is my new member name as i was having problems with my old one (chevycamaro4lif)
within the next month or two i will be putting my 91Z auto under the knife to convert to a t56 6 speed. i am currently runing 4.10s in the rear and love them for off the line accelleration but i hate them on the highway.what would be the best for a T56 both for highway and the strip use? i wanna be able to hit a buck 30 without being too close to redline.
P.S. after the tranny instal my 20 PSI 383 stroker project will begin and im plannin on getting a good 700HP+
already have the ford 9" rear end and most all suspension complete for the massive amounts of power.
Old Feb 2, 2004 | 10:57 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I would go with 3.73
Old Feb 3, 2004 | 09:33 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I agree with the 3.73 recommendation, particularly if a blower motor is in your future (or a turbo or nitrous motor for that mater).
Power added engines need less gear than NA motors.
I've got 3.73s behind a T56 and I love them. The off the line acceleration is great, and I still only turn 1,900 RPM at 80 MPH.
What T56 are you using?
Old Feb 3, 2004 | 01:30 PM
Car: 91 Z28
i will be using a 94-97 T56 and yes an ATI Procharger at high PSI is in the works
Old Feb 3, 2004 | 09:01 PM
I run a '95 T56 from a Z28 and have the 3.73s. It's important to know which trans because the gear ratios are different for different models of the T56.
The 3.73s should work well for your combo now, and with boost. Taller gears will probably lead to extreeme traction problems with the blower, and a fairly short first gear (you will have good RPM potential, but the way a blower generates instant boost will really take you through the cogs qucikly). Most guys with blowers are running 3.73s or 3.42s.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
