TransGo vs boost valve, vette servo
Old Feb 3, 2004 | 11:12 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
What are the benefits of installing a complete Transgo shift kit, which includes the .500 boost valve and the corvette servo, over only installing the boost valve and servo?
Old Feb 6, 2004 | 04:59 AM
Z69's Avatar
Z69
The timing of the shifts will be off some if you don't install the whole kit. You need to drill out the clutch release holes so that 2nd can release as fast as 3rd applies as an example. Down shifts are even harder to get right.
This is just what I've figured out from calling many tech lines and asking lots of questions and tons of net searchs.
All I know is, the whole oil system is balanced. If you change one thing, it will probably screw something else up.
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Doobie52
Sep 11, 2015 06:19 PM
scottmoyer
Sep 7, 2015 07:06 PM
tgp1990
Sep 4, 2015 06:24 AM
