need some help.
Old Feb 6, 2004 | 10:36 AM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
need some help.
ok im taking my tranny to the shop to be rebuilt and i was going to take it out my self and i had a book that had step by step how to do it and it said that i needed to take out the rear springs because when i disconnect the tq arm it causes the rear end to twist and can cause damage to the car. is there any other way? or should i just let the shop do it all. im getting it rebuilt with shift kit and vette servo and kevlar lacd bands and a racing cluch pack and a manual/auto valve body and some other stuff and im getting it all for 800.00. if anyone has any better way to take it out or if i should just let them do it that would help thanks.
Old Feb 6, 2004 | 10:41 AM
PhilM's Avatar
Car: Accepting applications...
I think they are referring to the upward twist of the torque arm whn you disconnect the front mount. All we ever did was brace it with a block or something to keep it from going up into the tunnel. I have heard of people really screwing up some sheetmetal like that.
Old Feb 6, 2004 | 12:39 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I always just rest the torque arm on the tunnel and have never had a problem with it damaging anything.
Old Feb 6, 2004 | 12:44 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
What I do is place jack stands under the frame of the car, where control arms attach. Then i jack up pumpkin and place jack stands under the tubes on the rear. This takes all of the tension off of the torque arm.
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
