91z28 rear
Old Feb 7, 2004 | 01:12 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
91z28 rear
Im about to buy a rear from a 91 z28. Its suppposed to be posi and have 2.73 gears. Also with the 28 spline axles. Does this sound right. How much would you pay for one with 70,000 on it.
Old Feb 7, 2004 | 02:09 PM
MdFormula350's Avatar
must of came from a 305 tpi auto.
it should be a 10 bolt and 28 spline.
disk brakes? no brakes? price hard to say right now a complete 10 bolt with disk and a better ratio and good posi i have seen go for 200 ish.
its going to cost money for a gear swap and a new posi. unless u want to use those gears.
Old Feb 7, 2004 | 02:20 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Sorry, it comes with drum brakes, e-brake cable, and rear sway bar. Is the rear sway from the 91z better than the one on a 82z.
Old Feb 7, 2004 | 02:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I personally would not buy it, except to get the axles. It's worse than a 6-cyl 90-92 rear (at least those had 3.42 gears and such).
Pass... you can do better.
The sway bar might be a bit stiffer. "Better" is all in the opinion of the driver.
Old Feb 7, 2004 | 02:37 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
It is replacing a 3.08 or 3.23 peg leg rear that came in the car. Isnt the posi just a big improvement. I want to keep gas milege since I have no overdrive. Could maybe eventually put 3.23's in it but I don't know. So what do you guys think, is it a good improvement over the rear I have?
Old Feb 7, 2004 | 03:44 PM
u can do better, heck u could get a v6 rear like already said with better gears and with alittle more money put a posi in it and have like a 3.42 posi.
i would pass, thats just me. posi is nice to have but still would to have a nice ratio also.
Old Feb 8, 2004 | 09:55 AM
Pat Hall's Avatar
It's pretty much a matter of preference whether you place the ratio or having posi higher on your priority list. I have a peg leg 3.42 rear I took out and a 3.23 posi that's in the car right now, and I have to be honest that I miss the 3.42 ratio even if it wasn't posi! I can also honestly say I can't think of a single person on these boards who would defend 2.73 gears as being a great ratio to have! In fact, there's a guy on the boards whose name is "2.73's Suck". Lol. Once again, it's all personal preference, by my pesonal opinion is that any gear ratio that's not at least in the three series isn't worth the time of day!
Old Feb 8, 2004 | 11:27 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
OK, well I knew 2.73's arent good but thought I would get some opppinions. I'll probably just wait then. Thanks
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
