Installed Zexel torsen take off today...
Old Feb 7, 2004 | 08:38 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Hey guys, just finished the differential install and I spun the tire and it spun the opposite direction, isn't posi gonna spin them both in the same direction?
Old Feb 7, 2004 | 09:04 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Put a little force on the tire that is rotating in the opposite direction and it should reverse its motion. Or just do a and look for the dual marks.
Old Feb 7, 2004 | 09:52 PM
pasky's Avatar
As long as it is normal, thats fine with me, i'd do the burnout test but the car has no motor .
Old Feb 7, 2004 | 10:47 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Installed Zexel torsen take off today...
Torsens are bizarre. They are not a Posi. It is normal for the wheels to rotate in opposite directions when the wheels are off the ground and then you rotate one wheel.
Things change totally when load is applied to the wheels.
Old Feb 7, 2004 | 10:53 PM
25THRSS's Avatar
Re: Re: Installed Zexel torsen take off today...
This is why I chose the eaton over the torsen. It takes load to get it to spin both wheels, which in turn would put more stress on the unit and allow for a slight, I say slight bit more wheel spin since all of this is happening in a split second.
Old Feb 7, 2004 | 11:07 PM
pasky's Avatar
Well, all I can say is im just happy I got posi. Won't ever have to worry about replacing clutches either. Its a street car so I don't mind the split second delay.
Old Feb 7, 2004 | 11:41 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
And the Torsen is just so nice in the rain....Oh c**p....just noticed. You live in Texas. May take a while to find out about that
Old Feb 8, 2004 | 12:54 AM
pasky's Avatar
Ummm, sarcasm?
Old Feb 8, 2004 | 09:31 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Ummm, sarcasm?
I live on the WetCoast...what do you think?
Old Feb 8, 2004 | 09:35 AM
Pat Hall's Avatar
Ummm, sarcasm?
Yeah, what pasky said! I'm curious too Chickenman, as I've never had the zexel-torsen unit. What weird things does it do in the rain???
Old Feb 8, 2004 | 09:48 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
No weird things at all....it's beautiful. Incredible traction when going around corners. Back end doesn't slide all over the place like a Posi or LSD.
Cornering in the wet... put the power down, tail comes out a a little...then she bites and off you go. It's just MAGIC!!!
Edit: Sarcasm was just that being in Texas, Pasky may never experience how GREAT a Torsen is in the rain.
Old Feb 8, 2004 | 09:58 AM
Pat Hall's Avatar
Cool, thanks for the info Chickenman! I may have to think even harder about getting one of those cheap take off units. I have an auburn right now, but I don't expect it to live forever.
Old Feb 8, 2004 | 01:45 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have the HD torsen and even in the wet I need to becareful. It is a touch better then my Nova (which has a clutch posi). I'm not sure if it is because it is the HD version but it acts very much like my Novas posi. Except when you have the wheels off the ground and spin one tire the other one does nothing, just sits there.
Old Feb 8, 2004 | 02:53 PM
pasky's Avatar
Question, ok I got the lid just bolted on right now, no sealant or anything because I havn't put the gear lube in yet, I see the fill plug on the inside of the cover but there is no opening on the outside of the cover, how can I refill it while the rear end is still in the car? Thanks.
Old Feb 8, 2004 | 09:30 PM
pasky's Avatar
Anyone gto answer for this? Wanna do it before it rains tomorrow ironically .
Old Feb 9, 2004 | 12:17 AM
pasky's Avatar
Found my answer, thanks anyways .
Old Feb 9, 2004 | 04:14 AM
joshwilson3's Avatar
Old Feb 9, 2004 | 08:42 AM
pasky's Avatar
I really can't tell you because my car is engineless at the moment, I got my LT1 right in front of it but need a new cherry picker jack. Im using 3.42's. I don't want to go any higher.
Old Feb 9, 2004 | 10:20 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Originally posted by joshwilson3
What gears work good with the torsen? Check my sig what from I've got. All stock, but slips as hell! Damn open 2.73, damn first owner. I was thinking 3.73, how does that sound? Or should I just go for 3.42? And can you guys suggest an install kit?
3.73's would work dandy. Ratech makes an excellant install kit.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
gixxer92
Sep 1, 2015 04:32 PM
