3.42 to 4.10 need to put speedo gears in a 5-speed how hard is it
Old Feb 8, 2004 | 10:09 PM
Lance Donlon's Avatar
Car: 91 1500 ex-cab pickup
Engine: 350 vortec
Transmission: 5-speed
Need to know what I need for this.
Hear it harder to do then just taken the tail shaft off like on a auto and its on a truck so I have to take the transfercase off to.
Old Feb 9, 2004 | 12:26 AM
25THRSS's Avatar
there is no accurate speedo ratio for 4.10's
Old Feb 9, 2004 | 12:31 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i will tell you this its easier to remove the tranny from the car to take the tailshaft off,you need to remove the roll pin from the shift rod,loosen the bolts to tailshaft and slide back it should take 2-4 hours to do.....
Old Feb 9, 2004 | 09:38 PM
Engine: 350 vortec
bigger tires
Well I have 285/75/16R tires on the truck could I get close with these bigger tires.
Is there a manual I could get or should I just talk to my friendly GM service man.
Old Feb 9, 2004 | 10:03 PM
25THRSS's Avatar
Prolly a 15/39 or a 17/45 may work, but you should checking using the match in this thread, also found in the tech articles.
https://www.thirdgen.org/techbb2/sho...t=speedo+gears
Old Feb 9, 2004 | 10:39 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Yes there is. I have it in my car right now, and it's up for grabs in the classifieds. Look it up, still for sale.
Old Feb 9, 2004 | 11:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Here check this out.
http://sethirdgen.org/t5speedo.htm
Old Feb 10, 2004 | 02:25 AM
25THRSS's Avatar
Hmmm, interesting. Maybe it came off of a truck with 4.10's. Do you know what got that gear? On the math issue though, I would make sure that is the right combo from gm before you put in on because the math the online calculators use is simply wrong and definitely does not coincide with what gm put in their vehicles.
Old Feb 10, 2004 | 01:18 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Wouldn't the speedo drive be on the rear of the transfer case on a 4WD? It was on my 78 Blazer. They would probably use special gears as well.
Old Feb 10, 2004 | 10:18 PM
Stingraye's Avatar
Car: 1986 Trans Am
Didn't come off of a truck or anything, I worked at a pontiac dealership at the time, and spend 25 mins with the parts guys lookin through gears for thirdgens, and finally found a special order 29 tooth gear to match a 7 tooth, which by doing the math works out to 4.14, and with my 16" tire it's right on the money.
Old Feb 10, 2004 | 10:28 PM
Engine: 350 vortec
are you sure on that I never even looked on the tranny or any thing to see where the speed sensor or cable is I just assumed
it was on the tranny
thanks for the tip. Petes 84Z28
I'll have to look.
Old Feb 11, 2004 | 12:28 AM
Fairly sure, because the hi/lo range in the transfer case would throw off the speedo if it were getting it's reading on the trans.
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
