THM 350 Problems
Old Feb 10, 2004 | 08:21 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
THM 350 Problems
I have a 350 trans that is not allowing part throttle downshifts 3-2 or 2-1. It will do a forced kickdown downshift from 3-2 and from 2-1. The trans has approx 4k miles on it. The fluid is fresh as well as the modulator (red stripe). Could this be a problem with the valve body or the fact that the modulator is hooked up with a rubber hose with no metal pipe between the intake and modulator.
Old Feb 10, 2004 | 08:24 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
I would say the vacuum hose is the problem. It collapses and prevents the modulator from releasing its vacuum hence no downshift. Go find the metal tube and use as little vacuum hose as possible. I bet that will cure your problem.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
