tcc connecter?
Old Feb 12, 2004 | 01:51 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
tcc connecter?
my friend ACCIDENTALLY painted on the tcc connection and he didnt clean it out cause there was dirt in there. is there any way i could replace it? or clean it?
Old Feb 14, 2004 | 09:58 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
alright thanks for the help everybody :lala:
Old Feb 14, 2004 | 10:23 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I'm not sure if you mean the pigtail or the socket part of the TCC solenoid that's on / in the trans.
In either case, I'd try & soak things in lacquer thinner & air them out. The former, the pigtail should be easy to droop down into a small elevated bucket. the latter, I dunno how easy removal is...
Old Feb 14, 2004 | 11:28 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The connector on the trans can be replaced, and it's not really all that difficult, just a PITA since you have to drop the pan to do so.
Old Feb 14, 2004 | 06:15 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
all the fluid is drained already so i shouldnt get to full of fluid
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
