Top Speed for Gear setups?
Old Feb 12, 2004 | 05:56 PM
firebird frenzy's Avatar
I've been thinking about this cause i know my 3:73's aern;t the greatest for breaking mach 9. Or maybe it just my engine, tranny, gear setup. Cause i'm running a th-350 and when i have the ***** to WOT on the backroads i run out of RPM's in a hurry. Guessamation at about 120. But she'll sure get there in a hurry.
Old Feb 12, 2004 | 08:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Top Speed for Gear setups?
So what is the question. Figuring out gearing and tops speeds is independent of engine power. Engine rpm does come into play and lets you go farther per gear as the max rpm increases. Also technically you can be power limited if you have to weak of a motor. But it boils down to tire size, tranny gearing, and rear end ratio.
Old Feb 14, 2004 | 10:51 AM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
Whats your red line at?
My buddy has a TH350 and 4.10's
he revs to 6500 and thats 127
You probably are going into the 115-120 range
Old Feb 14, 2004 | 03:10 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
You can either upgrade to a built 700R4, so you have a 4th gear, or swap out your rears for 3.23s (big difference) or 3.42s (a mid step), or get smaller wheels. Any of those would raise top speed.
Old Feb 14, 2004 | 06:30 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
He would have to get bigger wheels and tire not smaller. The smaller ones have a shorter circumference meaning less distance per turn. The larger tires will move forward farther per turn dropping rpm. I would say gears in the 3.08 to 3.23 range would be needed otherwise. Or maybe a comination of both.
Old Feb 14, 2004 | 09:30 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Whoops!
Old Feb 18, 2004 | 08:34 AM
91REdZTPI's Avatar
with 3.42's and a 700 mine will do 135 in third spinning 6300
and 165+ in 4th it just keeps pulling ls1 m6 cars can't run away on the highway since i put the 3-4 wot upshift valve in
Old Feb 18, 2004 | 08:47 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Its time for an OD trans my boy....
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
