look!please help with tko 5 speed
Old Feb 12, 2004 | 06:55 PM
chad89ta's Avatar
my t-5 is out on my car, i want an tko to replace it,here is the problem i have a costom crossmember made for the stock t-5 so that i chould run true duels on the car,it bolts up just like the factory xmember but gives me more clerance,i need to no if the tko will bolt up just like the factory t-5 does with the stock crossmember,so if the tko will bolt up to the factory crossmember then it will work with my coustom crossmember hope you guys can help thanks
Old Feb 12, 2004 | 07:26 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The stock type crossmember fits with my tko, but needed to be flattened a little on one edge and I had to drill one additional hole in it. Other than that, it needed to be spaced down about 1", as the tko is a bit taller than the t5. Some aluminum spacers came in the kit I bought.
If you can live with the crossmember 1" closer to the ground, it can be made to work.
-Rich-
Old Feb 12, 2004 | 08:41 PM
chad89ta's Avatar
rich where did you get your tko from
Old Feb 12, 2004 | 10:30 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i think he got it from Forte's.....thats where i got mine as well.....and like he said, it should fit
Old Feb 13, 2004 | 11:04 AM
Car: 92 Camaro RS
Yep, got it from Fortes.
http://www.fortesparts.com/tremec/tr3550.html
-Rich-
Old Feb 28, 2004 | 10:21 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ok guys i have a question..not abotu the Xmember or anythign else, but what is the torque rating on this beast?....its says 500 ft pounds, but im building a 500 ft pound 383 WITH a blower....im going to road race it ALOT...
isnt there a crossmember kit for it?
Old Feb 28, 2004 | 06:11 PM
Car: '91 Camaro RS
mine is rated for 525 ft/lbs.....but people are drag racing them into the 9's without much incident.......
they can also be rebuilt much stronger, should anything happen.....but i doubt it will.......drag racing on sticky tires and powershifting is about the worst thing you can do to it, and it stands up pretty well.
i think spohn might have a x member specifically for it
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
