Which T56 is best?
Old Feb 18, 2004 | 07:30 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Which T56 is best?
Which T56 had the 'good' 6th gear? I think I remember hearing that the earlier '92-'93 ones didn't have as good a 6th gear as the later ones??? This will be going in my daily driver, so MPG is a big deal.
Old Feb 18, 2004 | 07:48 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I think you mean '93, since '92 is still a 3rd gen and no T56 was available that year. The '93 trans has a tall 1st gear and 6th gear as a general rule. I've seen and heard of exceptions, but why take the risk with a '93 box.
You want a '94-'97 LT1 T56 from a Camaro or Firebird. Stay away from any other T56 (LS1, Corvette, ect.). This is the simplest trans to swap if you have an auto. If you've already got a T5 and have a bunch of cash tied up in the clutch, flywheel, and bellhousing you may want to use the GM AFtermarket T56, but you will need to shorten your driveshaft and torque arm.
Old Feb 18, 2004 | 09:24 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
I've got a built 700R4 now. So I'd want a '94 -'97 F-Body T56 with everything that comes with it?
Old Feb 18, 2004 | 10:39 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Yoou could use some items off a 3rd gen 5 speed as well to include the pedal assembly, clutch reservoir and slave cylinder from what I've read in past post. If you can get the complete set that came with the t56 but if not, maybe you can get it from a bone yard. Do a search on here, there was a member that did a write up on the installation of 5speed with pictures.
Old Feb 18, 2004 | 11:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Clutch reservoir and slave cylinder is too short for a six speed. You can use the mounting holes from the original for the cylinders for the t56.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
