des. need axel??
Old Feb 21, 2004 | 03:06 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
des. need axel??
ok i'm a 16 year old kid and my rear pinnion gear has so much backlash and i don't know how to fix it or if i did i don't think i would even be able to so my firend told me that it would be easier to put a new axel in the back i was wondering if any one had an extra one layin around or know were i could get one i'm in the twin cities area in MN well thanx
Old Feb 21, 2004 | 10:30 PM
25THRSS's Avatar
try ebay or the classifieds section here.
Old Feb 22, 2004 | 12:36 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Just start calling the junkyards listed in the yellow pages and ask for a rear for a '82-'92 Camaro or Firebird. They're all basically the same. Post '90 cars have 28-spline axels, which are a bit stronger. Gear ratios range from 2.73-3.73 depending on the application. V8 cars are more likely to have a posi, but plenty don't, even if they were loaded with options. The 9-bolt Borg/Warner is the strongest rear that these cars had stock. Both the 9-bolt and the 10-bolt could be had with discs. The aluminum PBR caliper discs are the really desirable ones.
Look for auto recylclers, auto salvage, or used auto parts in the yellow pages.
Don't act too eager, or like you really need the part. Buying stuff from junkyards is an art form that takes years to master. The price they initailly quote you is often more of a suggestion, so don't feel like you can't haggle with them. Get a warranty if you can. If you can't the price should go way down.
hectre13
Dec 11, 2023 08:14 AM
TBI89Formula
May 14, 2002 08:08 PM
1982chevycamaroz28
Feb 16, 2002 08:53 AM
UVA3rdGen
Aug 6, 2001 09:34 AM
AustinT
Feb 5, 2001 09:36 AM
