driveshafts the same?
Old Feb 22, 2004 | 01:00 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i was told that all driveshafts in camaros are the same length from 81 - 94. true? if not then which ones are bigger or smaller
Old Feb 22, 2004 | 01:03 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I know that all 700r4's and t-5's are the same length, and yes the LT1 and LS1 shafts are direct bolt in's as well.
Old Feb 22, 2004 | 01:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Not true. Some early cars had the TH200 which used a different length shaft. All 700R4s, T5s, T56s, and 4L60Es use the saem one though.
Old Feb 22, 2004 | 02:57 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
the v6s had the 700r4 right?
Old Feb 23, 2004 | 12:38 PM
Everything that had an auto after the first couple years used a 700R4.
Old Feb 23, 2004 | 12:43 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Except the TTA's, which had the 200-4R.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
