T5 about to die, I think...
Old Feb 22, 2004 | 07:22 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Wining noise while idling in neutral. I was thinking it was the caged bearing under 1st gear. Now I think its the needle bearings between the input shaft and the tip of the ouput shaft.
I guess I'll be pulling it back out as soon as I can the GTP fixed...
Old Feb 23, 2004 | 02:08 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It could also be the bearings on the countergear shaft. That spins whenever the input shaft does. Unless something's broken
Old Feb 23, 2004 | 02:28 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
I was wondering if it was the coutershaft bearings but here is the strange part...
At first, it would make noise when you came to a stop (idling in neutral). But if I let the car drift a little, the noise would stop. Now its a CONSTANT NOISE, but only when idling in neutral! Hell, I dont have a clue at this point.
The GTP is going in the shop tomorrow so I will be pulling the T5 soon.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
