Does anyone know of a beefed up 5 speed that's a DIRECT SWAP for a T-5?
Old Feb 24, 2004 | 12:44 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I did some searching and found out about the tremec TKO but it needs to be adapted to the thirdgens. I DON'T want a T-56 cause it will not bolt right on with ZERO modifications. I want a tranny that exactly replaces the T-5. I heard a rumor of a 6 speed that replaces a T-5 exactly but it is aftermarket. Can anyone shed any light on this matter? (TKO performance)
Old Feb 24, 2004 | 01:15 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, since you have a WC casing, you could upgrade the T-5 you have. No adapters needed, and it increases the trannys power handling...
Old Feb 24, 2004 | 01:57 PM
GASGZLR's Avatar
What needs to be changed? What's the weak link in the T-5 anyway? Gears?, shafts?
Old Feb 24, 2004 | 03:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Richmond makes a 5 and 6 speed tranny that directly replaces the T5. They are like 2 to 3 thousand though.
Old Feb 24, 2004 | 03:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Tremec TKO.
Old Feb 24, 2004 | 04:28 PM
camarokev400's Avatar
send your current t5 to g-force transmissions and have it built to handle 600 hp......... search the board and you will find info about gforce trannys
Old Feb 24, 2004 | 05:04 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The G-Force is the simplest option.
The T56 is very nearly a bolt in. You certainly don't have to modify any hard parts. The trans bolts right up, as to the hydraulics, and flywheel. You can reuse the stock driveshaft and torque arm. You need a custom crossmember, but they are available and a direct bolt-in (www.skulte.com worked like a factory part). The shifter hole needs to be stretched about 1.5" rearward, and some wiring is needed, but that's it. Not that bad for a trans rated to 450 lbs/ft with a .050 6th gear.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
