Slush shift
Old Feb 25, 2004 | 09:59 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Slush shift
I have a question for you trans gurus.
I have an 87 Formula with the 700R4, and I have the Trans Go, Gil younger No-Yo-Yo SysKoKal Kit, and it was descent shift, Matter of fact there is less than 10K on the trans.
I could on occasion get it to chirp going into 2nd.
This past summer, I put in a GM 24202310 2200 RPM stall Torque Convertor, and If I manually shift, the car will hesitate for a few seconds before shifting (really irritating), Its like the car is waiting for something... Another new thing is the car will (sometimes, more times than not) shift from 1-2 before I manually shift, at about 4000 RPM.
- What is causing the hesitation?
- Can I adjust something?
- Should I suspect the trans place that did the convertor swap for $180 changed my transmission?
- Would a Corvette Servo help with faster shifts?
Any help is appreciated.
Old Feb 25, 2004 | 12:31 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Well, there is a T.V. cable that you can adjust, but I would take it back to the shop that worked on it and have them take a look. Then get a second opinion. I have been screwed by a tranny shop before,I kick myself for not looking around. Sounds like you mainly manualy shift the car, so I think you should convert it to a full manual valve body. I always shifted it manualy, because I didnt like the way it shifted by itself, always late, sometime early.... So thats what my new tranny guy did, put a full manual shift kit in it, and I am floored by how flawlesly it shifts, and when I say to shift.
Old Feb 25, 2004 | 12:34 PM
okfoz's Avatar
They have done me good work in the past... Would the Throttle Valve Cable do that? (Unfortunately I will not be able to drive the car until May , winter up here
John
Old Feb 26, 2004 | 03:13 PM
MYBLUZ's Avatar
Engine: Blown 383
Yes, a misadjusted cable can make it shift all goofy, but if its never been adjusted since you have had the car, I would think its something else. They dont just come out of adjustment unless someone has messed with it.
Old Feb 26, 2004 | 04:43 PM
okfoz's Avatar
When they dropped the trans I imagine it could have come out of adjustment... will try that this summer... is it all the way forward or toward the back it should go?
John
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
