9" moser question
Old Feb 25, 2004 | 11:42 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
9" moser question
I have a retro T-56 which required me to shorten my DS by ~2". I have a 9" that cam out of a 3rdgen camaro that I'm putting into my GTA that has a 10 blot in it now. I want to know if I'll need to shorten the DS again to make this swap go smoothly.
Old Feb 25, 2004 | 11:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if the 9" was a bolt in replacement, all the mounting points should remain the same.
so in that case, your existing driveshaft should work.
you will need to look at the U joint and make sure they match.... or get a "conversion" u joint that lets you connect the two.
or you could forget abotu it and give the whole axle to me.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Irocguy01
Sep 28, 2015 02:03 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
