View Poll Results: How does a 4spd auto tranny work
3 gears then TQ converter locks for a fourth
75.00%
4 gears then TQ converter locks for a fifth
25.00%
Voters: 4. You may not vote on this poll
Help me settle a bet
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Is a 4spd automatic tranny 3 gears, then the TQ converter locks for a fourth. OR is it 4 gears, and then the TQ converter locks for a fifth gear?
Car: 4
Engine: 6
Transmission: 5
It is 4 gears. 3rd is direct, 4th is overdrive (drive shaft turns faster than input).
The converter lockup isn't a gear. It's just a clutch that directly connects the engine to the trans, somewhat like a manual trans clutch.
so your saying that the whole bet is wrong.....
OK...well then, what does the TQ lockup do?
for me it was hard to notice direct gear. at first i thought it was only 3 gears + OD cuz i could feel 1-2 and 2-3 easily but never 3-4. after i put in the higher stall i noticed right away i had a 4th gear cuz there is a noticeable RPM drop. then again the RPMs drop when shifting into OD.
K...this is in my cousins Lumina, but he says he put it in D and on the highway, it still went OD. Any explanations other than he's blowing smoke up my @ss
Car: 4
Engine: 6
Transmission: 5
It didn't. What he thinks is OD, is the torque converter clutch locking up.
The usual order of trans events as the car accelerates is 1st-2nd, then 2nd-3rd, then the clutch sometime during 3rd, then some time later, 3rd-4th (4th being OD).
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
excellent. im gonna try to kill that tranny so i can get one from 700r4.com i know painless makes a kit so you can maintain the lockup and ditch the computer
Chevykid810
Sep 28, 2015 12:57 PM
