700R4 Tranny dead again...
Old Feb 29, 2004 | 10:03 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, after fixing my governor (gear was stripped), and repairing the governor cover (it was previously installed incorrectly, by hitting it with a hammer in the center, not around the edges...), the car was finally road-worthy, or so I thought... Now the car cant get out of first again, and feels just like it did when it had the stripped governor gear, so I'm pretty sure its the same problem. I've had it with this thing and I'm ready to just buy a re-build kit, but I think I'm just jumping too fast. Do any of you guys have any idea on what could be causing my tranny to keep leaving me with only first gear? It almost feels as if I rev it up high enough, that it wants to go into second, but cant quite make it in. I think I was too pissed off when this happend that I didnt fully asses the problem, so I cant describe in more detail than that.
Thanks!
Old Mar 1, 2004 | 02:27 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Could be an internal problem with the govener like the weights or springs. Or they might just be the wrong ones for the apllication. If your sure you put the tv cable in correctly id look at your govener as the problem before id get the rebuild kit.
Old Mar 1, 2004 | 07:15 PM
AM Racer's Avatar
If the gear was stripped, I'd be concentrating on the gear that runs it. If it got eaten too, the governor isn't operating.
Old Mar 1, 2004 | 09:47 PM
Scott_92RS's Avatar
Car: 1992 RS
Thanks for the info guys. I'll check out the TV cable (again) and pull out the governor again this weekend, but I have a feeling that I'm going to be taking that sorry POS of a tranny out in the near future
Scott
Old Mar 2, 2004 | 12:12 AM
86WS6_T/A's Avatar
Car: 2003 Mach 1
That's what happened when I swapped the new motor into my car. Lost everything except first and reverse.
I think I'm going to have to pull my money out of savings for the hood I was wanting to get a T56...
Old Mar 2, 2004 | 06:37 AM
Scott_92RS's Avatar
Car: 1992 RS
I'd love to get a T56, but man, I'm SICK of dropping cash on this thing. I've been doing it forEVER, and I've got no results. I'll figure something out I guess...
Old Mar 2, 2004 | 12:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The output shaft drives the governor directly, there is no plastic drive gear for it, just the gear in the metal of the output shaft.. Doubtful it is damaged...
Old Mar 29, 2004 | 08:14 AM
Scott_92RS's Avatar
Car: 1992 RS
Well, Mike (1bad91z) and I removed my transmission Saturday night, and I popped the governor cap on Sunday morning. The gear is perfect, no problems at all. What would cause me to only have first gear if the governor is stil good? A tranny tech that Mike talked to said it could be a contaminated valve body (with piece of my old governor gear). Any other possibilities? The tranny felt like it wanted to shift @ about 4500-5000 rpm, but it just couldnt, it just kept "bucking".
Old Mar 30, 2004 | 08:01 AM
Scott_92RS's Avatar
Car: 1992 RS
Anyone have any ideas?
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
6998poncho
Sep 25, 2015 02:56 PM
