T56 swappers, got a question...
Old Mar 4, 2004 | 01:13 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Did your exhaust hook up on the t56 (metal peice with a rubber type clamp on the passenger side) give you problems in positioning the tranny? Mine seems to be catching the frame.
Old Mar 4, 2004 | 03:36 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
No, it sure didn't. That's one little tidbit that every set of instructions I've ever read conveniently leave out.
What I did was section the T56 exhaust hanger 1.5" from the longest section of the hanger. Then I built a custom hanger that bolted to the existing cat on the car and had a bracket coming off it that slipped right into the rubber part of the modified T56 hanger. It took a little while to build, but it works like a factory piece.
BTW, I've got a single cat car, so dual cats are probably a whole other ball of wax.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Vincent135
Sep 28, 2015 10:50 PM
