Top Right Tranny bolt
Old Mar 6, 2004 | 01:10 PM
echo5blud's Avatar
Car: 1986 Z28
Engine: 305...350/383 in progress
Transmission: 700r4...fresh rebuild
Ok, here is the deal....I got it out..but it hurt like hell....this top right kicks my *** everytime I mess with the tranny...it's the one that has the dipstick tube mounted with it....I've TRIED to get at it from the top, but I couldn't.....any tips anybody has so I don't have to squeeze my hand back in there to line up the socket would be much appreciated...
Old Mar 6, 2004 | 02:04 PM
ede's Avatar
ede
long extension, flex socket, tape the bolt to the socket
Old Mar 7, 2004 | 01:11 AM
wuter's Avatar
with tranny mount unbolted, put a jack under the tail of the tranny, and lift it a little, this will tilt the motor enough so it can easily be removed from the top
Old Mar 7, 2004 | 02:32 PM
Pat Hall's Avatar
I prefer the method ede mentioned much better than trying to reach it from the top. I have a 3/8 extension that's about 3 ft. long with a wobbly tip. I use that along with a universal joint and a short six point socket. Then I use a 1/2 to 3/8 adapter so I can get it nice and tight using a bigger ratchet. That extension I got is the best tool I've ever had for getting to tranny bolts. When you combine the wobbly tip along with a universal joint, you have plenty of flexibility to get on the bolt from almost any angle. If you have your crossmember out of the way, you can also lower the tranny down some with a floor jack to give you a little more room and a better angle. The only way I could ever get them out from the top was using a wrench, which takes way too much time!
Old Mar 8, 2004 | 10:30 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Bah you dont need it. Theres so much redundency in bolts on cars. 5 lugs. One to hold the wheel on and 4 just in case. Same deal with the trans hehe.
gta90
Sep 15, 2015 04:00 PM
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
