4 prong plug on 700
4 prong plug on 700
i switched from tpi to carb and yanked the comp. my buddy "accidentally" cut the plug that goes to the tranny off and threw it out, just wondering if i still need it since it aint computer controlled anymore, and if i do, do the wires come from the fuse block?
If you totally ditched your computer, you shouldn't need that plug anymore. It's the wiring that contols the lockup on the 700r4 torque convertor, and the ecm is what controls it.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
stupid *** me, i just did the same thing as im doing my motor swap, from 350TPI to a carbed ZZ4, so i janked the whole computer and i saw that the tranny lines are on the harness, well it was a little to late to fix it, so now i wont have lockup, what if i put a stall converter in, will that fix it, or if not and i stick with the stock converter, what can i do to fix it, since the ECM is all gone....
Car: 1985 Pontiac Trans Am
Engine: 5.7L 350
I have a question related to this if anyone can answer.
I have an '85 TA that orginally came with a carbureted 305. We are putting in a carbureted 350.
We're getting a new distributor that does not hook up to the computer. We're not hooking up the emissions.
If we plug the 4-prong back into the transmission, will it work correctly with all that considered?
The tranny is a 700r4.
Thanks in advance.
Thanks in advance.
Car: 89 RS
Transmission: TH350
Thanks in advance.
Thanks in advance.
Theres a tech article on this site that goes into detail. Basically run the wires from the plug inside the car, hook the purple wire to ign.+, and run the tan wire to a switch of some sort, then run the other side of the switch to a ground. Now, USE THIS WITH CAUTION. You could damage something if your out there messing around doing dough nutz with the switch on. First gear will act the same from a stop, then every gear after that will be locked with the switch on. If its working properly, you will notice that the car will act like it has a manual tranny when slowly rolling in secon gear. It will kinda jerk around when you give it gas. Best thing to do is use it when you are on the highway cruising for a while, save a few pennys in gas.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Thanks in advance.
Thanks in advance.
As far as making a switch for the TC lockup, it really shouldnt be used in any other gear than 4th. The lockup mechanism in the torque converter isn't really designed to be used under much acceleration.
You can tell if its working or not, because the TC lockup should feel like another gear change. Accelerate slowly, and after you feel it shift into 3rd, it should feel kinda like it shifts again, and the RPM's should drop a few hundred. Also, when the TC is locked, when you tap the gas a little, the car should jerk like a standard, instead of feeling 'lagged' like a non-OD automatic.
Car: 87 IROC Z28
what if you get a non lockup torque convereter, will that fix the problem.
But im kinda liking this whole thing that it act like a manual and it will shift faster, or whatnot, but is it safe to do burnouts witht eh switch on or should the swich be off.
and should the switch be on all da time, or just in 4th like stated above, thanx for the replys guys, i need the info.....
Transmission: 4L80E/4L80E
The ECM doesn't lock the TCC until it goes into closed loop.
If it doesn't get the required info from the sensors, it doesn't go into closed loop.
tonys91rs
Oct 10, 2015 03:31 PM
84 TA NV
Sep 6, 2015 08:02 PM
