how do you swap gears
Old Mar 8, 2004 | 08:41 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
I have a one legger and I would like to know how to swap gears?
Old Mar 8, 2004 | 09:15 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You do realize that you can't just swap gears to get rid of the peg leg? You have to swap the entire center section or differential.
Old Mar 8, 2004 | 10:27 PM
Engine: 5.8
yes you need a posi to get rid a one legger,I just want to know how to swap gears and if is is the same for a posi and a open
Old Mar 9, 2004 | 05:08 AM
ede's Avatar
ede
swapping gears is pretty straight forward, same for either kind of rear. setting them up to the correct spec takes a little more effort.
Old Mar 9, 2004 | 05:55 PM
Engine: 5.8
how about a step by step
Old Mar 9, 2004 | 07:08 PM
ede's Avatar
ede
how about the search button or the drive line section of your manual?
basically r&r the pinion
swap new ring gear to carrier
install carrier
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
